Member Since 05 Jul 2013
Offline Last Active Jun 05 2014 07:17 AM
In Topic: Admitted Defeat 2.0 Tdci Breaking
05 June 2014 - 07:14 AM
I spoke to my ford dealer mechanic who is a friend and he said my psa 2.0 tdci does not have coced injectors have a look on website autodiagnosis.look under support/manufacturers specific diagnosis,
04 June 2014 - 10:16 PM
it does sound egr related,when its programmed in it is told when to shut and when to open,if not programmed it might not be fully shut when starting from cold,best test blank it off and try it nothing to lose mate?
04 June 2014 - 06:55 PM
put a blanking plate on the egr to rule out egr as sounds like it could be that as your symtoms sound like a unprogrammed egr?also my 2.0 tdci 2005 does not have coded injectors seems strange yours has,as you have a new maf in it wont be that,does sound egr related thou?
04 June 2014 - 08:46 AM
just another thing injectors in the 2.0 litre don't have to be programmed in like the  1.6 tdci and like the mondeo tdci, there are no injector codes written on the injectors if you look at your injectors.are you sure egr has been coded values relearned in every engine you have put in?when I bought mine it was smoking and had a stutter so I thought I will clean egr out.when I looked I see previous owner had put a new one on it so I phoned him and he said they don't need coding in but I took it to ford and they did need coding,also a software update was needed?
if I was you to be certain its not egr make a blanking plate and put it in at the connection where the silver pipe comes out the top of the egr,also try disconnecting the maf and see if the smoke stops.
03 June 2014 - 06:18 PM
ok mate feel for you been where you are now when I had a tdci mondeo,I spent good part of £3000 on it and it just couldn't be fixed,will take some pics of pipework when get a chance maybe tomorrow ok mate.
