Member Since 05 Jul 2013
Offline Last Active Jun 05 2014 07:17 AM
Part Number
19 December 2013 - 07:20 PM
hi again folks after a part number from anyone in the know,im after a rubber o ring gasket that sits between the intake manifold and the anti shudder valve or throttle housing on my 2005 2.0 tdci focus,hope someone can help many thanks.
Low Idle
12 December 2013 - 08:53 PM
hi folks a little problem just started the last couple of days,its happened twice now start car up and it idles really low when engine hot,turn it straight off and try again and its fine any ideas folks?
Foglight Rings
12 December 2013 - 11:03 AM
anyone know if you can buy chrome rings for the mk 2 focus foglights as it would look good with them I think ?
06 December 2013 - 10:55 AM
hi folks I need two new front tyres on my 2.0 tdci, fitted to the rear are nearly new goodyear efficient grip 205 55 16 91v and the fronts are a rubbish make but are 205 55 16 94w xl , can I put the same goodyears on the front or do they have to be the 94 w xl ?
Dashboard Clocks Dimmer
14 November 2013 - 06:05 PM
hi folks just found a problem my stereo illumination was flickering at idle and have found the culprit the dimmer dial for the dash,if I set it for high the stereo illumination flickers but turn it down a touch it stops,i don't think its worked right since I had it because always thought clocks were not very bright so question is could I clean the switch with contact cleaner,many thanks.
