minimadgriff
Member Since 07 Jul 2013
Offline Last Active Mar 05 2015 10:07 PM
In Topic: Coding In Two New Remotes
01 March 2015 - 09:28 PM
I can get hold of the PATS in and out codes, it is just having the equipment to do it.
I have two of the later style fobs I want coding to the car.
In Topic: Retro Fit Of Oem Xenon Headlights To Mk2/2.5
06 May 2014 - 07:36 PM
Thanks, :) Did you have to swap any pins around?
06 May 2014 - 06:53 PM
No one?
In Topic: 06 Ford Focus Mk2 Welcome Lights
05 May 2014 - 01:15 PM
He want's the "coming home/leaving home" function when locking/unlocking the car. So when you unlock it the dipped beam comes on and when you get out the car the dipped beam stays on for a short period after you lock it. Like on VAG models.
As mentioned above you have to manual activate this by pulling the left stalk towards you before exiting the car.
There is nothing to activate this when locking/unlocking in ELMconfig. I wish there was as I would like the same.
Don't suppose anyone has worked out how to wire this into work off the locking/unlocking system? Think it is something UCDS need to look into, as I am sure if could be done through the GEM if you have the ability to reprogram it.
In Topic: Problems After Recon Turbo Install
02 March 2014 - 09:53 PM
This will more than likely be the VNT's or actuator not set up properly when the turbo has been re-con'd.
Seen it so many times.
