Member Since 15 Jul 2013
Offline Last Active Feb 16 2014 07:01 PM
In Topic: Mondeo Mk4 Duratec Fuel Pump
16 February 2014 - 07:06 PM
Sorry dont have a part no. and the only way to access the loom is from underneath. You can get at it if the cars rear is jacked up high enough. Its drivers side. This small loom connectors give alot of grief on the diesels too apparently.
16 February 2014 - 04:02 PM
Just a follow up incase anyone else has this problem. It turns out there is a small loom about 12" long that runs over the rear subframe from the pump to the main loom (about £7 from Ford). This over time shakes about and gives a bad connection which in turn eventually can burn out the pump. Best to check the connector block pins on this small loom as a first port of call. You might be lucky and just have to replace this short loom unlike me!! We replaced two pumps before finding this. Hope this helps.
30 September 2013 - 06:12 PM
Ford only part and the tank must be dropped to access the pump. im.told sometimes a wonky fuel gauge is also a sign of the pump failing.
