Member Since 23 Jul 2013
Offline Last Active Jul 25 2013 06:34 PM
In Topic: Rust On Sportka
25 July 2013 - 05:47 PM
Streetka don't rust as bad as normal "hard top" ka's they don't rust around the petrol filler caps because streetka's have rear wheel arch liners so don't get the mud and !Removed! collecting in areas that are prone to rust, only real areas to look for is the bottom of the front inside wheel arches behind the front wheels, bottom of the sills and any exposed areas of the floor pan which can easily be seen by looking underneath
In Topic: Streetka Starter Spinning After Engine Switched Off
23 July 2013 - 11:16 PM
It's only spins for a second or two after switching off so not sure at the moment if its spinning will driving, and only just had new starter motor fitted
