Clarky82
Member Since 15 Aug 2013
Offline Last Active Aug 19 2013 08:20 AM
In Topic: Oil Pump
16 August 2013 - 07:14 PM
Thanks would there be a problem if he doesn't have the ecu for it
In Topic: Oil Pump
16 August 2013 - 04:33 PM
Fantastic thanks I think that's going to be the best bet just to replace the whole block if they are the same :)
In Topic: Oil Pump
16 August 2013 - 04:14 PM
Thanks, I've found complete engine but the engine code is hxda rather than hxdb would this cause many problems or would I just need the ecu as well
In Topic: Oil Pump
16 August 2013 - 03:43 PM
Thanks, some1 i rang about a spare said that they used chemical metal to repair the hole and the car is still running, not sure weather to do that as a short term fix til I locate one as the car won't be used very much, would any one know the torque setting for the Conrod ends please, thanks for all the info and help
In Topic: Oil Pump
16 August 2013 - 02:14 PM
Hi thanks I've stripped the oil pump that's all fine I have found a crack in the bottom end of the block where the oil chamber runs through, so I'm after a bottom end if anyone knows of one engine code hxdb thanks
