GlynnZS
Member Since 22 Aug 2013
Offline Last Active Feb 25 2015 12:57 AM
In Topic: St Is Getting More Power Next Week!!
21 February 2015 - 05:38 PM
If the maf housings they have sent you is not the same diameter as the original one then it's for a different car, ZS maybe. For the maf sensor to get a correct reading on airflow it has to be inserted into a housing tube of the specific diameter that the ecu is calibrated to, so if you change the diameter you will need a new custom map that tells the ecu this.
21 February 2015 - 03:56 PM
I'm away this weekend so can't take pics of the parts, but I've had problems with the light coming on and loss of power while coming up to the lakes, so I took the map off and it's fine. Weird coz I've had the map on since Sept with no issues.
Both maf housings should be exactly the same diameter, so that is definitely your problem!
In Topic: Xvision Daytime Running Lights
23 January 2015 - 04:19 AM
My personal opinion is that any drl's that aren't oem look cheap and tacky
In Topic: Rs Tuning Leeds-Dyno Run-Anyone Interested In A Group Buy?
22 January 2015 - 05:21 PM
I'm up for doing it soon, definitely don't need better weather!
In Topic: Poorly Fieata :(
17 January 2015 - 07:59 PM
Poor Percy doesn't sound well at all! I'd ask at a Ford parts desk
