Member Since 30 Aug 2013
Offline Last Active Feb 19 2015 02:07 PM
Remote Starter Wiring
15 February 2015 - 04:25 PM
HI guys and gals, as states, I'm gonna be starting installing a Falcon rs500 remote start tomorrow, just one little thing. I've located the ignition wires to the left of the stearing colum. please tell me if im right or wrong with the wires
theres five wire
Green/Yellow = Start wire or ignition
Red/Green = unknown
RED = +12volt
Yellow = ACC
Grey/Orange = Cranking or Ignition
as you can see im not to sure which is Ignition wire.
Also the system I am installing has a input to detect rpm that should go to the coil pack but as mines a diesel where do I install this wire as the system needs to detect the engine has started and where is the wait to start wire.
Remote Starter Install Mk1 Focus Starter/ignition/crank Wire
15 February 2015 - 02:55 PM
Hi guys and gals, as title says. I'm installing the remote start today/tomorrow thing is before I start I need some advice on a few wires. I've located the ignition harness under the stearing wheel colum to the left of it.
Thing is which wire is which, I know the red is constant 12+, yellow is the acc wire, then theres the green/yellow is this the starter wire or ignition? and plus the grey/orange wire is the cranking wire?
Tddi Mk1 Wait To Start Light
18 January 2015 - 04:54 PM
Hi guys and gals, got a remote starter kit for xmas and nearly installed apart from the wait to start wire. Ive got the instrument panel out and removed the wiring harness thing is which wire is for the wait to start light? Cheers in advance
Focus Weird Noise Front End??
01 January 2015 - 10:24 PM
Hi all, just a question about a weird noise that has just appeared. Seems to be coming from the front, when i drive in reverse there is no noise but when i drive forward this noise is there. It sounds like metal rubbing. Ive driven down the road and taken it out of gear and it still there when i coast. I filmed or tried to film to get the sound on vid to post on here for help. The vid is only 15.6mb yet i cant upload it. Its bugging me. Cheers peeps
Mk1 Estate Load Sensor To Abs
05 December 2014 - 08:42 PM
Hi guys and gals, as the title states, when I done the drum to disc conversion I noticed that there was the ABS plug where the sensor can be plugged in. The question is can I remove the load sensor from the rear and connected brake pipes straight to the calipers and add the ABS sensors? What do I need to look for ect, I have the sensors from when I got all the conversion parts. Cheers
