slemon123
Member Since 01 Sep 2013
Offline Last Active May 19 2014 09:22 PM
In Topic: Please Help Mondeo 1.8Tdci 57Reg
28 February 2014 - 11:13 PM
Starting problems are either egr , inlet manifold, injectors or the vibration damper. It could be worth having a look at the immobilizer as that could be faulty. Clutch and dmf doesn't make sense to me either.
28 February 2014 - 10:31 PM
See what you think of this. It could be this simple. You'd never know.
http://www.slideshar...ations-problems
11 February 2014 - 09:34 PM
I'd be thinking the inlet manifold is clogged up or else egr. As stated above blank off egr first to rule that out. Then look at manifold before going at dmf and clutch.
In Topic: Remove Diesel Fuel Injectors.
03 January 2014 - 12:12 AM
Thanks for the speedy reply. That's what I thought.
02 January 2014 - 11:59 PM
Can anyone definitively tell me the procedure for when the injectors are put back in. i.e. Do they need to be primed or does cranking the engine do the trick?
