Member Since 07 Sep 2013
Offline Last Active Sep 28 2013 02:00 PM
In Topic: Oil Leak, Gearbox
28 September 2013 - 01:54 PM
As Argen suggested, the cover was very easy to remove (most unlike modern stuff) :) I attach a picture below ... looks to me like I've a rather tricky to fix leak coming from where the gearbox linkages enter the gearbox, I guess there may be a seal I can replace or some magic stuff I can add to the gearbox oil that will rejuvenate the seals and gaskets :( I really wish the gearbox had a dipstick too so I'd have some idea of any fluid loss :angry: Any advice very welcome :rolleyes:
11 September 2013 - 04:27 PM
Just replaced fan resistors, fan now works on all speeds, air con l;ight doesn't mysteriously go out. But I'm unconvinced air con works, no doubt that a seperate issue!
11 September 2013 - 04:01 PM
Thank you so much for your reply Arjen. I see you've made some interesting mods to your Fusion!
I'm am off to clean the offending area now, I will update as things progress, I'm in no hurry as I have another car I'm using until the Fusion is sorted :) x
