rg1642
Member Since 16 Sep 2013
Offline Last Active Mar 18 2015 08:04 AM
In Topic: Focus 2006 1.8 Tdci 'engine Systems Fault' Again!
18 March 2015 - 08:04 AM
Fixed! Seems I was barking up the wrong tree. It was the fuel pump that was faulty. A total coincidence that it came up after an electrical fault. Ever since I bought it I thought it was just a little down on power than the other 2 focus's we have in the house but put it down to being a Mk 2. New pump and it's the same as the Mk 1's. Very costly to repair and if the rest of the car hadn't been perfect I think I may of scrapped it but there you go. This may be of use to someone else with similar symptoms.
04 March 2015 - 05:59 AM
Sorry should have said I did that and got a couple of ohms but didn't think that was significant. I've ordered a new valve for now and seeing if it does the trick. I know its a gamble but if it isn't the fault at least I can go to Ford and say it is an electrical fault and leave it to their diagnostics. :)
02 March 2015 - 09:00 PM
Bump :) Anyone?????
In Topic: Bonnet Open, Erratic Rear Wiper And No Blower!
22 February 2015 - 10:33 AM
If the locking bar isn't fully latched that's a very likely cause as the connector won't lock in properly otherwise and you'll only be getting partial contact with some of the terminals.
Spot on buddy. :)  Just to wind this thread up thanks for all the suggestions. The locking bar about a quarter of the way up, probably courtesy of my sons mate's big feet! I must stress to anyone with similar weird problems it was only a tiny fraction out of place, not the half over I at first thought, so there we go problem solved.
Thanks again
Russ
21 February 2015 - 12:14 PM
Ive taken the GEM out and no sign of water, but........................................
one of the sockets had the clip half over when I was takeing it out. Still Ive done some contact cleaner and it will go back in tomorrow.  We shall see. :)
