Member Since 19 Sep 2013
Offline Last Active Sep 29 2013 07:20 AM
Mk5 Fiesta Air Bag Light Problem
19 September 2013 - 08:06 PM
I have a mk5 fiesta (2001) 1.25 ghia 5 door
and the air bag light flashed once then went out, then flashed once again then went out again, then stayed on after 5 times of flashing
I took it to a fords dealer and they hooked it up to a pc and it came back with a faulty clock spring.
i ordered a new one;fitted it this evening, put it all back together again and this time a new air bag flash sequence appeared.
this time it flashes 3 times then goes off, flashes 3 times then goes off and after 5 times of it doing this it stays on constantly
i googled the flash sequence and this is what i found
"Three flash cycle: Short to battery plus or ground in section of air bag squib circuit common to both driver and passenger air bag modules"
I haven't got a passenger airbag, just seatbelt pre tensioners and drivers air bag.
what does that quote mean?
