TitaniumSteve
Member Since 07 Mar 2009
Offline Last Active Sep 27 2009 10:55 PM
In Topic: How do i know when my car was first made
19 September 2009 - 04:10 PM
Unless they have changed it, it was free when I registered few months ago
In Topic: Footwell lighting
18 September 2009 - 11:41 PM
Sorry can#t give you step by step guide as I not done it on a Fiesta.
18 September 2009 - 11:35 PM
When you install them do not use the switch wire them straight to the curtesey light. The wiring to cut out the switch comes with the instructions when you buy them. Or you could leave in switch which ever you prefer. Best way to find the correct wires is to unsrew your curtesey light switch then trace the cable futher back to a convenient point then cut cable and wire in paralle with the neons. To check you cuttin the correct cable use a 12V light tester, it should only be live when curtesey switch is on, or out.
18 September 2009 - 11:26 PM
I am glad I found it quite straight forward so I was wondering where you were stuck. Hope it gives you the info you want.
In Topic: i found this on face book :(
18 September 2009 - 11:23 PM
That might struggle with a MOT test.
