cressws1
Member Since 08 Mar 2009
Offline Last Active Jan 29 2013 07:49 PM
#148374 Guide To Fitting Mist Type Jets On Your Ford
Posted by cressws1 on 13 October 2011 - 11:54 AM
Fitted these to my mk1 Focus today. Much better. What a brilliant little cheap modification this is. One quick question, Is it possible to adjust the spray direction on this type of jet? I used to adjust the normal ones by using a needle in the jet etc. The mist seems to hit my windscreen a bit low down thats all.
#147339 Guide To Fitting Mist Type Jets On Your Ford
Posted by cressws1 on 06 October 2011 - 07:52 PM
In that case, Ordered!
#94199 Recommended Led's
Posted by cressws1 on 22 August 2010 - 06:23 PM
The colour of your speedo is not determined by the colour of a bulb it is a coloured film on the bits that light up (all the numbers, dashes etc). I looked into changing the whole film myself and a few on here will tell you horror stories involving losing mileage etc so I decided against it. All the other bits and bobs (clock, heater controls, air con switches etc) can be changed for LED's but the speedo is different.
#82247 Mk1 Spare Wheel
Posted by cressws1 on 17 May 2010 - 06:07 PM
There should be two screw in hooks one shorter one for the jack etc and a longer one for the wheel
