Member Since 30 Sep 2013
Offline Last Active Apr 03 2014 05:01 PM
In Topic: Reversing Camera
03 April 2014 - 05:00 PM
Depends where you are putting the Camera.
If you are using the number plate light Cam then you will have issues going through the grommet.
I would suggest running across the roof lining.
If your mounting in the bumper, then run along the side trim.
Good luck
In Topic: Ford Focus 1.6 Headlights Dim When Bass Hits
03 April 2014 - 04:53 PM
This is a classic Audio problem.
The current draw is higher when the Bass audio is kicking in. There is a easy thing to sort.
I would suggest a Power CAP on the power input to the Amplifier. There are tables that will say what value is required.
But I would suggest a 1Farad cap should do the trick.
These are not that expensive, but go for a good make Cap as the cheaper ones are a little pony and not true to the value.
If I can suggest a retailer, I have worked close with Gavin at G7 Sounds. These guys know the products and trade.
You can say you spoke to JustConnect and they may do you a good turn.
In Topic: How Can I Connect My Ipod To Car Stereo System?
06 March 2014 - 10:36 PM
Hi Katie,
Check out the Dension Product.
Depending on your radio in the car there will be a compatible product that will allow you to plug in your iPod and use on the original stereo.
If you do want to use a good FM modulator we have a universal solution on our site and it will plug and play.
In Topic: Dab And Dab+ Into A Factory Fiesta Radio
26 February 2014 - 11:27 PM
The most popular solution that we have for the Fiesta is the JustDrive Kit.
This is the basic DAB & DAB+ solution that puts the station name on the screen and is operated via a small credit card remote.
This solution has proven to be very reliable and in real terms you can select instantly the station required and all the volume etc is dome via the normal controls in the car.
We also use a interface on Ford that will plug into the factory USB port and operate through the Media interface (AUX selection)
On the Fiesta the control is slightly limited but you don't need the remote and all functions are done on the radio unit.
Price on these solutions is a fully fitted price at your home or place of work.
JustDrive (Remote) £179.99 until the end of Feb
JustDrive USB £229.99 also until the end of Feb
Please visit www.justconnectme.co.uk and book your DAB upgrade.
In Topic: Got Factory Usb But No Dab Or Dab+
06 February 2014 - 09:46 PM
Let me know how you go with this kit?
I have done lots of testing with the AutoDAB.
If you have the factory USB we can integrate via the media input and not transmit by FM,.
