Member Since 02 Oct 2013
Offline Last Active Oct 31 2013 08:06 PM
#301286 ! Guide ! Fitting A 12V Socket In The Boot Mk7
Posted by ooda55 on 31 October 2013 - 07:39 PM
Hi what fuse position did you use mate....
I want one that's always on manual says I have a few free can I use them
like 20,22,30,31 are not used ..which one have you used any help for a novice would be much appreciated thank you
I went with what looks to be number 22 in the manual. I simply probed around the empty sockets with a multimeter (ground connected to chassis) to find a +12v with the ignition off. Oddly in the manual #22 is listed as "cigar lighter, front power point".. Which you would think would already have a fuse in it seeing as my front cigar lighter works...
Here are a few pics of the fusebox with the fuse tap installed, and where I mounted the socket: http://imgur.com/a/DMKdu
