Jules9143
Member Since 11 Oct 2013
Offline Last Active Dec 24 2013 12:03 PM
In Topic: Bonnet Release Cable Snapped
24 December 2013 - 12:04 PM
How easy is it to replace the bonnet release cable on an  S-Max?  I got as far as removing air filter, battery cover and battery, but how on earth do you remove it from the bulk head in the passenger well?   The cable just disappears up behind he wiring loom. :(
It is a two man job as it comes in from behind the carpet to the release handle to gain access, you will need to remove the passenger plastic trim from around the door seal and fold the carpet back until you uncover the hole it comes through.
I also found easier to remove the large electrical connector with the metal clamps to gain access to the hole in question.
then one person pushing it through from engine bay and the other in the foot well to pull it through.
Shocking design, routing and not an quick job.
Regards
Jules
18 October 2013 - 10:36 PM
Have you treated it to prevent it snapping again in the future?
No i haven't as the new cable now comes with a rubber boot over the elbow to stop this happening again.
Regards
Jules
In Topic: Roof Bars - Lost Mounting Bracket
13 October 2013 - 10:43 AM
Hi Stephen,Thierry,
I have a similar problem in that my domed shaped pads in the fitting have split and cannot find any parts to replace, I know this is of no help but i am looking at replacing the whole system withthe Thule units as they are replacable, costly but in the long term best option i have found so far.
There are some full systems ford genuine on E-bay at the mo if you can get them cheap enough might be only help.
Regards
Jules
11 October 2013 - 06:26 PM
Hi all,
New member, thanks for the above advice helped alot, I would just like to add that if you have the 2.2 TCDi then this is a lot harder job as there is a air charge cooler, in the way and the horn mounted at the right hand end of the cooler.
It is a bit of a git to remove, but straight forward job to do with very little mechanical knowledge.
Took me 3 hours to do it in all, once cooler removed there is the air intake above it which makes life hard to gain access to the bolts mentioned above as it is clipped in on top, bottom and both sides, but again straight forward enough and I have big hands recomend using a 10mm rachet spanner once losened of by ratchet to allow better access ( and to reduce the swearing and spanner rash )
Top tip before refitting remove your head lights ( 2 x Screws and 1 x Cable ) to allow better access to the hoses at either end of the cooler back together in 30 mins much easrier.
In all easy job for a mornings work and for £22 for the cable and to save £130 labour charge :) , but if you have access to ramps or a pit that would be much better than using a curb as i think removal of the cooler would be a big swearing job, at least portable car ramps to allow better ground clearance.
