BrynC1994
Member Since 27 Oct 2013
Offline Last Active Jan 08 2015 09:06 AM
Fiesta St500 Mk6 Airbag Light
07 January 2015 - 05:24 PM
Right, I removed the passenger seat in my car to clean where someone was sick, (still not happy about that) so had the guy come clean it and everything but In between that I had to drive the car and the airbag light came on, didn't worry to much thought it would turn off as soon as I put the seat back in and plug it in, but the light has stayed on, does anyone know if this is just a simple case of erasing the fault code off the ecu or have a done something wrong removing the seat? Cheers
Urgent Radio Code Needed
12 July 2014 - 09:11 AM
Hi Guys,
at work and going to be handing over a ford fiesta last of the old shape (58) and the workshop have let me know it needs a radio code with it going out at 2:00pm have rung ford and they are basically not going to help because saturday isnt a good day for them? and chance any of you know the code? it is the Ford CD the new style one single CD not DAB serial number is **********
*edit* Its a sony ford single cd
Installing Parcel Shelf Speakers/amp
03 May 2014 - 12:17 PM
Hi all,
Finally getting around to fitting my rear speakers to my ST500 fiesta, im going to have an amp and 2 rears on the parcel shelf running with the front and rear standard speakers, my question is what is the best way to fit and run my Amp power cable, remote on/off cable and rga leads to the boot so i can hook it all up?
Fiesta St500 Bi Xenon Upgrade?
29 January 2014 - 11:01 PM
Just bought a 35watt Bi Xenon upgrade kit for the car and I was told I might need to buy and install canbus decoders does anyone know whether or not I need too? Cheers
Fiesta St500 Mk6 Hunting/rev Limiter Issue
07 January 2014 - 09:08 PM
Hi Guys,
noticed lately when sitting still with the engine running the engine is hunting a little, I mean not a huge amount about 100rpm max either way of around 900rpm and it not like constantly a 100rpm it moves its just constantly up and down by varying degrees and I was just wondering if this is normal? :unsure:  the other thing I have noticed is that it isn't bouncing of the rev limiter like I think it should, the other day being a bit of showoff I did a bit of a burnout for my mates and had it bouncing off the rev limiter like ba,ba,ba,ba,ba,ba,ba,ba we all know the sound, but recently I revved it out of interest because I noticed the hunting and when it hit the rev limiter it over revved then dropped revs, paused then over revved again with about a second between each over rev like vrooooom...............vrooooom.........vroooom and so on with my foot to the floor the whole time rather than the usual ba,ba,ba,ba,ba,ba am I being stupid here or is this something I should investigate further? and just a minor question under heavy breaking from high speeds is it a safety feature that the hazards start flashing till I let off the brakes?
thanks in advance for you help.
Bryn
