Shezzy
Member Since 10 Nov 2013
Offline Last Active Dec 02 2013 06:45 PM
In Topic: Focus 1.8 Tddi - Turbo Noise
16 November 2013 - 09:25 PM
I will check that tomorrow and try to post my video how it performs, so maybe you will know the issue.
However it's the noise than you can hear much better in your car than staying in front of open bonnet.
16 November 2013 - 09:13 PM
I've checked the main hose from turbo to intercooler and from intercooler to manifold.
They looks fine. Clamps were not loose and I could not fill any air blowing from hoses.
However I've no idea what other hoses I could check.
In Topic: Focus 1.8 Tddi - Major Oil Leak From Right Side Of Engine
16 November 2013 - 12:30 AM
It works.
No leak anymore.
However let's see how it will be in long term.
Now I need to change oil and all filters. Cheers.
15 November 2013 - 12:14 AM
It leaks from vaccum pump cover.
Since I won't get spare one before Saturday, tomorrow I will try repair existing one.
I've drilled rivets and opened the pump, tomorrow I will get M5x20mm bolts with nuts. I will use existing o-ring with black loctite silicon.
Hopefully I will fit it tomorrow and see if it helped.
Fingers crossed  :lol:
12 November 2013 - 10:19 PM
Right I've got an exact instruction how to remove vacuum pump and fit it back, but it says that I need a gasket?
However I can not find gasket anywhere, do you think that oil resistant silicon would be enough?
