Reyesz3
Member Since 15 Nov 2013
Offline Last Active Feb 18 2014 05:30 PM
In Topic: Need Help Removing Airbox
17 November 2013 - 10:33 PM
iirc
its just the casing pushed into rubber grommets
if you can give those grommets a good coating of wd40 it will ease removal and lessen chance of snaping the casing
aahh i see ! i'll have another go at it again and let you know the results, thanks mate  :)
17 November 2013 - 09:43 PM
I remember my car guy had problems getting out the casing, as the engine so compact where air box is I think he used force and wiggling but dont use to much force will crack the case and are u sure u have undone all bolts
theres actually no bolts or screws as far as i can see, which is why im alittle confused as to how to remove it.
i could try use abit more force to pry it from the pipe but it doesn't seem to be the only thing holding it down :L
i dont think it matters if the airbox breaks im installing an induction kit after all :L
16 November 2013 - 03:18 PM
ok so heres the bottom of the airbox thats stuck
http://imageshack.us...5/5491/gja0.jpg
and heres the pipe i think is holding it down but doesnt want to move
http://imageshack.us...0/4933/ywju.jpg
and the airbox location itself
