sazwahhh
Member Since 15 Nov 2013
Offline Last Active Nov 17 2013 04:57 PM
In Topic: Help End My Nightmare Before Christmas!! Idle Issue Fiesta 1.4 Zetec
17 November 2013 - 03:32 PM
Ok so start with:
HT Leads
Clean idle control valve
Reset base setting of throttle butterfly.
See if that works if all else fails..
Temp sensor
02 sensor (is this the lambda sensor?)
Thanks :) your a star!! I will update in the week hopefully can find a decent mechanic now!
Sarah
17 November 2013 - 03:16 PM
Just been searching and apparently I have a TMAP sensor? Also some people say to change HT leads what are these??  Apparently garage tried a coil pack but no difference but im wondering if I should try all three?
17 November 2013 - 03:07 PM
Manual 2003 1.4 Zetec
17 November 2013 - 02:52 PM
Throttle body or maybe at a push could be the MAF sensor.
Ive been told there is no MAF sensor on my car? As electronic pedal? Not sure if this is correct.
17 November 2013 - 02:49 PM
If the engine is in high gears then it is smooth but low gears/idle it judders the needle shakes up and down then cuts out when slowing down/coming to junctions.  It is even worse when cold but slightly better when engine warm but not amazing.
