ELushion
Member Since 15 Nov 2013
Offline Last Active Apr 19 2015 07:52 AM
Rubber Trim Above Windscreen
18 April 2015 - 01:47 PM
Hey guys. My focus has the common problem of the rubber trim just above the windscreen blowing up often. I then have to get out and push it back onto the top of the windscreen.
I tried getting it done via warrenty but trim is not covered. So whats the best way to stick it back down. Im happy enough to glue it to the top of the windscreen as if the screen ever comes out the rubber will be replaced anyway. I just want a neat tidy job and not have to push the rubber back down every 100 miles lol
Rubber Windscreen Seal
03 June 2014 - 03:07 PM
Hi guys, I have got an issue with my Ford. Apparently its very common. The rubber seal along the top of the windscreen has lost its stick, and every couple of hundred miles blows up. This makes a rattling noise in the wind and requires being pushed back on to the top of the windscreen. Now I know this is only superficial and no cause for concern, but I want it fixed. The car was in warranty but apparently that does not cover the rubber trims.. great. So basically it needs glued back to the windscreen. I dont mind doing this as the seal would need replaced anyway if the windscreen was replaced so no big deal.
Anyone got experience with this and the best way to do it?
