mick85
Member Since 17 Nov 2013
Offline Last Active Yesterday, 10:05 PM
In Topic: Focus Charging Battery Light Abs Etc
26 May 2015 - 10:54 PM
Say u need an alternator check wat battery charging at
In Topic: Cambelt Change, Not Starting
08 March 2015 - 10:11 AM
Did u disconnect fuel pipes U need prime it if any fuel system disconnect
In Topic: Replace The O2 Sensor On My Fiesta
27 February 2015 - 05:56 PM
Pre cat sensor 1 post cat sensor 2 wats fault code
In Topic: Engine Limit Mode
24 January 2015 - 06:14 PM
Wat is Ur fault code I can check wiring diagram see if I can shed some light on it for u
In Topic: Aircon Pipes Disconnected On My Focus Mk2 2006 1.6
24 January 2015 - 05:36 PM
If u do decide get fixed make sure they vacuum system for at least 30 mins before putting gas in there be loads of moisture in system after been open for so long
