mick85
Member Since 17 Nov 2013
Offline Last Active May 26 2015 10:52 PM
#489884 Focus Charging Battery Light Abs Etc
Posted by mick85 on 26 May 2015 - 10:54 PM
Say u need an alternator check wat battery charging at
#448121 Aircon Pipes Disconnected On My Focus Mk2 2006 1.6
Posted by mick85 on 24 January 2015 - 05:36 PM
If u do decide get fixed make sure they vacuum system for at least 30 mins before putting gas in there be loads of moisture in system after been open for so long
#448097 Key Cutting Code
Posted by mick85 on 24 January 2015 - 05:02 PM
#429622 Location Of My Core Plugs
Posted by mick85 on 19 November 2014 - 12:06 PM
There two core plugs at spark plugs rocker cover needed be removed
#354687 Timing Belt Replacement
Posted by mick85 on 18 April 2014 - 08:38 AM
If it's built after feb 2007 I think that when wet belt came in really horrible job bout 9 hours labour
#352022 Ford Focus 1.6 Tdci Engine Problem
Posted by mick85 on 08 April 2014 - 07:25 PM
Depends on how turbo fails if turbo breaks up u then u remove the sump an clean everything out an replace turbo feed an return pipe or a good clean u don't run the engine wit metal particles an try changing oil load times he must be a right thick
#351998 Ford Focus 1.6 Tdci Engine Problem
Posted by mick85 on 08 April 2014 - 06:58 PM
Omg how stupid is that place i would be getting them pay for new engine it's there fault why did they tell u ya needed a new turbo an did they fit second hand one then makin u buy injector u defo have strong case there
#348844 Rumble
Posted by mick85 on 30 March 2014 - 01:09 AM
Dual mass flywheel
#337349 Snagglepuss Build Thread Lenny's New Whip
Posted by mick85 on 28 February 2014 - 07:52 PM
Lenny a quick compression test an sniff test this checks for exhaust gases in coolant this will tell u your head gasket but also in cold weather u will always get bit cream at oil cap an bit white smoke it's usually from short drives to work or shops condensation build up in engine
#330809 Power Steering Stiff
Posted by mick85 on 09 February 2014 - 11:54 AM
I would start with a fluid flush take off return pipe at bottle put a blanker on bottle then get help of a friend help u hold pipe in bucket get ur friend start engine lock steering side to side u keep topping up till clean fluid make sure u constantly fluid goin through don't want pump running dry for long
#328291 Fiesta Zetec S Tdci Wont Start
Posted by mick85 on 02 February 2014 - 12:33 PM
They checked the head an skimmed it why did they do that
#328152 Pats Fault 1:5 Not Starting After Battery Change
Posted by mick85 on 01 February 2014 - 07:26 PM
Is Urs keyless
#325441 High Mileage Maintenance Diesel Focus 2010 (Zetec)
Posted by mick85 on 24 January 2014 - 07:09 PM
Always let car heat up before puttin foot down when u have turbo u should always make sure oil changed regular an always let car idle for at least a minute before switching off u want turbo always have constant oil feed I wouldn buy cheap diesel either
#323219 Power Steering Pump
Posted by mick85 on 18 January 2014 - 05:45 PM
No special tools required remove fan belt an remove pump 3 or 4 bolts I can't member exactly but should be straight forward
#322607 Wall Of Shameful Driving
Posted by mick85 on 16 January 2014 - 09:48 PM
James u seem to attract bad drivers haha I would invest in helmet they were close absolute dickheads
