AJRTDDI
Member Since 28 Nov 2013
Offline Last Active Yesterday, 11:11 PM
#483173 I Need Advice Asap. (Disabled Parent Only Transport)
Posted by AJRTDDI on 06 May 2015 - 06:26 PM
The engine is now running if i run 12v to diesal pump and ecu also reads.
There must be a problem with wiring to 109 relay. I replaced it today and i have same issue.
Anyone got diagram to trace back the wiring
#449554 Lowering And Alloy Size
Posted by AJRTDDI on 29 January 2015 - 08:58 AM
17s with a 30mm drop should be ok. You could fit the ST170 legs and brakes and get a 20mm ish drop
#446248 Fiesta Mk6 Headlight Hid Retrofit
Posted by AJRTDDI on 19 January 2015 - 08:09 PM
I seen a 2014 bmw smashed into the wall this morning when i walked the dog. I guess he wasnt use to it lmao
#446036 Fiesta Mk6 Headlight Hid Retrofit
Posted by AJRTDDI on 19 January 2015 - 11:29 AM
Im currently making a set for my mk4 escort with black enimal surrounds. Mine was 6k also. I love the new bmw headlight system. I love how the light moves around cars so it dont dazzel um at all. On youtube :)
#438512 England Flag Illegal?
Posted by AJRTDDI on 21 December 2014 - 07:20 PM
I agree. Socal media and newspaper do talk rubish most of time. But where else can we get our info??? .. lol
#427040 Show Us Your Clean Focus!
Posted by AJRTDDI on 10 November 2014 - 12:28 AM
Colour looks nice on that shape focus. I never use soap on my cars. Just damp cloth then a wash. Once every 6 months give it a good wax.
#426416 Attempting To Install A Usb Port On Dash..help!
Posted by AJRTDDI on 07 November 2014 - 11:45 PM
U can get surface mount version of metallica picture. I had a twin port done on my headunit. Make sure u check on headunit my Usb port could pull 2500ma. Most ports are 500ma.
#426413 Focus Mk2 Foglight Wireing
Posted by AJRTDDI on 07 November 2014 - 11:41 PM
I'd suggest there tied back on the loom. I can't see ford making up different looms. I usento work at dhl/jag and landrover. We had 1 main looms for like 6 diff trim levels.
#426409 Need Help For More Power!!!
Posted by AJRTDDI on 07 November 2014 - 11:23 PM
Didn't insult your shiney camshafts lol
Vtec was a great design of keeping torque and high end power. High lift cams slow u down with normal 1000-3000rpm driving
#426098 Need Help For More Power!!!
Posted by AJRTDDI on 06 November 2014 - 11:03 PM
U need grand just for mapping and ecu. This route is only if your serious want more power. But engine swap would be better. Or sell ur car and get a ST225
#425626 Fiesta Mk6 Headlight Hid Retrofit
Posted by AJRTDDI on 05 November 2014 - 03:28 PM
I'm a mot tester for a couple of years.
I wouldn't fail the car on washers because your car was built before 2010. But self leveling projectors aren't the same as height adjustment. In the cab.
My mk4 escort as self level projectors off eBay for 60quid
#425507 Need Help For More Power!!!
Posted by AJRTDDI on 05 November 2014 - 12:30 AM
Service, free flowing air filter, custom rolling road map to suit your engine.
#414194 2005 Focus Key Fob Issues
Posted by AJRTDDI on 27 September 2014 - 11:40 PM
I agree with stoney. You will need a virgin chip/transponder to be programmed to the car.
#396232 Escort Tddi Pulling To The Right
Posted by AJRTDDI on 10 August 2014 - 08:17 PM
It gets overlooked on older cars sadly.
If it was my car is check all bushes and balljoints then brakes and carriers. If all that is fine I'd look for accident damage.
Sent from my HTC One X using Ford OC mobile app
#373210 Gearbox Question
Posted by AJRTDDI on 10 June 2014 - 08:38 AM
would be fine mate.
