AJRTDDI
Member Since 28 Nov 2013
Offline Last Active Yesterday, 10:17 PM
Ford Galaxy Again Ecu Help.
12 May 2015 - 02:32 PM
Hey guys. I ordered a new ecu after testing the whole loom. Ecu was grounding engine module all the time and even bypassed i couldn't get it to work. All fuses and relays are fine.
Anyways new ecu will need programing orcan it be removed ? Any help please
I Need Advice Asap. (Disabled Parent Only Transport)
05 May 2015 - 05:22 PM
My dad said the car was running alittle slow. I ran dignostic and come up a mass air flow sensor error code.
My dad wiggled the plug and engine cut out. I stripped back the plug and wires was damaged and shorted out.
I cut and solider new loom and reconnected maf. The engine is no longer starting.
Iv checked all fuses and relays (level 1,2,3) also power to diesal pump. (All fine)
The laptop (vag com payed verson) will no longer connect to the engine. Yet worked fine before and in past.
Maf Sensor pins are reading 3k resistence. (Think should be over 10k)
Maf power is reading -0.01v. (Think should be 5v or 12v normaly)
Im guessing the ecu as shorted out its power supply rail, Worth a gamble replacing ecu? Or can i bridge power to that rail to see if it runs ?
Anyone Seen This Car. Was At Blackpool Meet In 2010.
14 January 2015 - 03:08 AM
My ex girlfriend sold this car of mine about 5-8 years ago. Was wondering if anyone knows if its still about.
England Flag Illegal?
20 December 2014 - 10:15 AM
There as been alot of cases of cars with england/union jack flag's being stopped by police and handing out spot fines recently.
Is this a new law or will it be dropped in court ?
I have a england sticker on my rear windows. (4 inchs square) ?
St170 Pats/imb Wiring
19 December 2014 - 07:04 AM
There 4 wires on receiver surround on key
Pin 19 grey/orange -- Pats TX signal
Pin 53 white/green -- Pats RX signal.
Are the other 2 pins a live and ground ?
Alittle lost lol
