riverside red
Member Since 29 Nov 2013
Offline Last Active Dec 01 2013 01:56 PM
Pad Change And Abs Problem Advise Appreciated
29 November 2013 - 10:10 PM
Hi, on a cost cutting excersize I youtubed pad change for a 2010 focus, followed all instructions, really worked well. but !!  at low speed cornering the ABS seems to kick in.  it appears that when I C clamped the piston back I should have  opened the bleed valve, instead I forced it back up.  Is this the cause of the problem.  Would bleeding the system remedy the problem. Any advice appreciated. Mike. I need hope.
