M4RC
Member Since 30 Nov 2013
Offline Last Active Apr 30 2015 08:56 PM
In Topic: Coolant Leak. Help!
29 April 2015 - 09:57 PM
Do you get any drips under the car, or find any residue under the bonnet?
I would also check the pressure cap on the reservoir, as I know these can fail.
Not that I've noticed but as its not a major leak I would probably never see. The pressure cap seems okay
In Topic: Js Performance Induction Hose? Help...
26 March 2015 - 08:38 PM
Attached File  ImageUploadedByFord OC1427401667.709835.jpg   95.33KB   5 downloadsAttached File  ImageUploadedByFord OC1427401680.250315.jpg   95.42KB   6 downloads
In Topic: Dash Cam Problems...help!!!
26 March 2015 - 08:35 PM
Just for future viewers...... I have overcome the problem off the dash am turning itself off/cutting out and it now stays on 24-7.
I done this by adding a voltage booster/stabiliser so the voltage now stays at a stable 17.5 voltsAttached File  ImageUploadedByFord OC1427401502.509397.jpg   96.48KB   11 downloadsAttached File  ImageUploadedByFord OC1427401523.102991.jpg   61.16KB   11 downloadsAttached File  ImageUploadedByFord OC1427401540.279911.jpg   293.72KB   12 downloads
19 March 2015 - 10:23 AM
Same here and it works find with just a 2 amp fuse for the dash cam circuit.
Marc have you tried connecting it to a standard 12v cig adapter? If it has the same problem then I don't know what you could do. Unless you can set the camera to not turn off automatically when it loses power, or maybe turn off after a few seconds and not instantly.
Connecting it to any fuse etc.. Is not the problem anymore. I could connect it to any fuse and it will still turn off when the car is started.
I've bought a voltage booster/stabiliser to steady the voltage so I'll try that out
16 March 2015 - 10:34 AM
