AdeMk1
Member Since 21 Dec 2013
Offline Last Active Today, 12:53 AM
In Topic: Mot Failure... Incorrectly Aligned Front Spring
11 August 2015 - 08:01 PM
As stef says it will be that the spring will have rotated round 3" and the end of the coil won't be resting in the stopper.
No big deal, I'd bet you can jack up the car, take the wheel off, grab the spring and give it a good yank to twist it round the 3" to seat it properly without having to remove the strut or spring.
Blummin' Halfords monkeys!
In Topic: Ford Mondeo - Titanium 2009 Tdci 2.2
28 July 2015 - 06:41 PM
It is yes, i was referring to the engine in my titanium, sorry for the confusion!
In Topic: Ford Parts Or Non Oem
28 July 2015 - 03:57 PM
As Mark said, Gates and Dayco are used as original equipment from the factory on many cars.
Personally i always use Gates kits.
26 July 2015 - 10:58 PM
Same as mine exept mines a 2006. The usual DMF failure, EGR valve, fuel pump, injectors, have the crankshaft pulley checked & also the auxiliary belt tensioner and idler pulleys are known to fail.
Other than that enjoy it, same engine as the ST - 155bhp.
In Topic: Leaking Black Liquid So Guessing Oil Related Help!
26 July 2015 - 10:35 PM
Glad you got it sorted, not as bad as first thought then.
