Member Since 27 Dec 2013
Offline Last Active Mar 12 2014 07:53 PM
Focus 1.8 Tdci 2002 Crankshaft Sensor Location
29 December 2013 - 08:49 PM
HI, ive got a fault with my focus tdci 1.8 2002 and it wont start without easy start. My diagnostics is showing p0335 Crankshaft position sensor A malfunction. Ive looked everywhere on my engine and cannot find this sensor, ive ordered a new one and was told the sensor was next to the starter motor but i still cant find it. Can anyone explain exactly where this sensor it please.
Ford Focus Tdci 1.8 Injector Problems
27 December 2013 - 06:52 PM
Hi everyone, im new to the forum i recently bought myself a 2002 ford focus ghia 1.8 tdci. It developed a problem and kept failing to start without easy start, it also cuts out at about 2000 rpm and the glow plug light flashes. Ive changed the fuel pumped, glow plugs, fuel filter and now 2 injectors as i done a leak off test and 2 and 3 had massive leak. I havnt yet recoded the injectors but it is still failing to start and cutting out. My fault codes are as follows on dtc.
p0100 mass air flow sensor,
p1211 injector control presure above or below,
po335 crank shaft sensor malfunction,
p2291 inhector control presure too low,
p0201, p0203, p202, p0204 all injectors malfunctioning.
p0251 injection pump fuel metering malfunction.
Im no further forward so decided to see if anyone else had any clues to what my problem could be. Thanks :) any advice would be really helpful.
