Member Since 02 Jan 2014
Offline Last Active Feb 01 2014 05:20 PM
In Topic: Loud Whooshing Coming From Engine
07 January 2014 - 01:37 AM
Check the large diameter hose that feeds the inlet manifold. It is secured with two pipe clips. Get a silicone replacement off ebay for about 7, don't bother with Ford. Takes about 5mins to do yourself.
In Topic: Electical Mayhem! Keyless Crazyness! Mk2 1.8Tdci
04 January 2014 - 10:53 AM
Thanks guys.
It is quite likely the pcm has received damage due to electrical surge. I have the diag equipment so I will check that asap.
I have had it with Ford and with an Auto spark and got charged a good bit of money to be told it is "fine".
Stoney I will check that right now. That is quite likely cos Ford garage wrecked the fuse board hinges. It doesn't swing up anymore and it is VERY easy to kick it and the connections.
Will let you know how I get on.
