Member Since 07 Jan 2014
Offline Last Active Oct 19 2014 05:06 PM
Ford Owners Club Sticker
16 June 2014 - 06:59 PM
Hiya just wondering where i can get the owners club sticker from?
Sent from my GT-I9505 using Ford OC mobile app
Drl Lighting Install
16 June 2014 - 06:48 PM
Evening everyone! Am after some safety check advice, have got a drl kit to fit to my mk2 ford focus im going to run the wire threw the grommet on the bulk head to a switch in my glove box then to the battery to the lights with a fuse in the wiring does this sound the safe way to do it? I want the lights on a switch so there at my control! Thanks very much
Helpppppp Misfire On Ford Focus 2005
07 January 2014 - 06:59 PM
Hi all I have an issue with my 2005 1.6 zetec focus. Basically it developed a misfire whi h turned out to be from the core plugs leaking I have had them replaced and new sparks it kept misfiring after that the garage then replaced the ht leads and coil packs and another set of sparks setting the gap to 1.3mm is that right? But it is still misfiring im 3rd gear usually when I have taken a corner then I put full throttle on and the car jumps but only a couple of times and nothing to extreme as when it first had the misfire issue.... any ideas what the problem is? The spark plug gap incorrect? ? Thanks in advanced
