Member Since 08 Jan 2014
Offline Last Active Mar 03 2015 07:31 PM
In Topic: Key Fob & Central Locking
23 April 2014 - 09:37 AM
You might have to re-program it to the system again.
In Topic: Ford Focus Mk1 Central Locking
10 April 2014 - 11:28 AM
Don't follow the guide !
Its for a 2001 model which uses a central locking/anti theft module, models from 2002 have a GEM and the wiring is different.
Actually its for a 1999 model as that's what I have. :)
I wasn't aware of the change as I don't have a new model to try it on. Might be worth adding that info to my post?
In Topic: High Mileage Focus Hesitant Starting
30 March 2014 - 06:37 PM
I have a similar issue with mine, 1.4 135K 1999.
Occasionally it will take several seconds to start, normally it is instantaneous. It usually happens after a short journey, but not always.
In Topic: Timing Belt Renewal Cost
25 March 2014 - 02:35 PM
I paid £160 sans the water pump, if I had known then what I know now I would have had it replaced at the same time.
I got a new pump off ebay for £17 so if it goes at least I am in a place to get it replaced quickly.
But as has been said depends on where you take it. This was a one man "garage".
In Topic: Central Locking Help?
21 March 2014 - 11:40 AM
How old is the focus?
Does it sound like it is locking then opening them again?
If the last then it is probably a bad connection in one of the door locks. Check out the FAQ there is something in there about it.
