Member Since 08 Jan 2014
Offline Last Active Nov 12 2015 07:27 PM
Mk1 Lower Front Grill Removal?
17 March 2014 - 06:49 PM
How do I remove the lower grill ?
I want to install some DRL there and mounting them off the car would be easier.
Mk1 Easy Place To Pick Up 12V Switched Under Bonnet?
08 March 2014 - 12:02 PM
It there anywhere I can pick up the 12V switched supply easily under the bonnet or do I need to feed a wire from the cabin?
Trying to run power to some new DRL's I got today.
Mk1 Antenna
11 February 2014 - 02:24 PM
I am trying to replace my stock antenna, as it is looking a bit the worse for wear.
BUT When I unscrewed it, I was left with a @7mm screw poking from the base. Is this normal or does it unscrew from the base.
I ask as most of the replacements I have seen have a 5-6mm screw fitting with the screw being from the antenna not the base.
Mk1 Airbag Light On
24 January 2014 - 06:14 PM
My MK1 has started showing the airbag light OCCASIONALLY. It is usually cleared by switching off the engine and restarting. (so far)
Any clues on where to look?
Not Staying Logged In
22 January 2014 - 07:10 PM
All week I have been getting logged out. Was fine last week.
I have cleared my cookies for this site, but the issue still returns.
Using FF 26 On Linux Mint 16.
