sambo87
Member Since 09 Jan 2014
Offline Last Active Today, 02:56 PM
Dual Mass Fly Wheel To Single Conversion
13 November 2014 - 06:25 PM
Hi all I have a ford focus 1.8tdci 2007 and the dual mass fly wheel is on it's way out was wondering if any body has ever fitted a conversion kit I have heard some bad reports about gear boxes and cranks getting bent any body got any horror stories or good feed back would be greatly appreciated thanks Sam
Abs Fault
11 March 2014 - 09:08 PM
Hello everyone just wondered if anybody has got any advice for me I have a 2007 focus tdci and had a new genuine ford wheel bearing fitted to the car recently at my friends garage and the abs light came on as soon as I fetched it. My friend thought he could have damaged the sensor when removing the hub but he replaced the sensor and still no joy when it's plugged into his snap on computer it comes up with no signal to the side in question and doesn't reset. I then found out that if I bump start the car while moving at speed the abs light goes out and all seems well until I turn off the car so today I have stripped down the passenger side wheel and followed the abs cable back to the abs module which is hard wired in different to the genuine ford cable I have fetched today I tested the cable but it tested fine running out of ideas now could this be my abs module !Removed! itself all advice would be appreciated even if it is to set fire to the !Removed! thing thanks Sam :-)
Egr Valve Blanking
09 January 2014 - 10:59 AM
Hi does any one know the affect of blocking off an egr valve on a 2007 focus 1.8 tdci or have already done it think mines on the blink cheers Sam
