Member Since 09 Jan 2014
Offline Last Active Feb 16 2014 09:00 AM
In Topic: Fiesta Mk7 Drl Fitting Guide!
16 February 2014 - 09:03 AM
I got this relay which was posted few pages back.
It not come yet but. you say it should reach. I notice on the picture it has a fuse. And I read you should disconnect the drl if gong for an mot. Will it fail an mot if they see the lights working. And by pulling the fuse will it stop working completely. So to pass tr mot?
And did you replace the led wires with stronger ones and did you change the end of the wires connection. Mine has the w5w connection I think thank you hope u help
You will find it is easily long enough and will even allow you to run it underneath the plastics at the front of the bonnet out the way of any moving parts. I haven't taken mine through MOT yet but to be safe I would just take the fuse out which will turn your DRLs off until you have passed :P
I soldered new wires on as the originals aren't really thick enough and put bullet connectors on the ends of the wires from the end of the relay and onto the DRLs although you could actually get away with soldering the two together and putting some heat shrink over it just to keep the water out.
So to get these DRLs working nicely all you need is a soldering iron, clear silicone (to seal the rings to the casing if you get the casing) and some bullet connectors. Obviously you will also need the standard tools to take the headlight units out and the washer bottle to get to the hex screws behind the passenger fog too.
In Topic: Access Rear Light Bulbs On Mark 7
15 February 2014 - 10:30 PM
Probably worth adding that not sure there is really any point in having the wing nut on? I took mine off and left them off and they have been fine since.
15 February 2014 - 10:23 PM
I purchased the ring led and that relay. But I noticed on the ring led the leads are really short like 10cm. How did you connect it to the relay? Please help thank you.
If you got the same relay as me, you should find the relay wires are easily long enough to go from about where the fuse box is, all the way over to the driver side fog & passenger side fog. What I did do though, is replace the wires on the LED rings because the standard wire is flimsy and likely to break from bumps when driving etc.
In Topic: Fiesta Zetec S Twin Exhaust
03 February 2014 - 09:20 PM
I'm pleased you like it! A lot of people have asked me if its worth the money and all I can say is yes! The longer I have it the more I love it!
02 February 2014 - 09:26 PM
Chrispage1 do you have any close up pixs
I don't have any real close ups right now but can take some.. next weekend is probably the next opportunity I will get when it's not dark.
Pics here -
