rockett
Member Since 10 Jan 2014
Offline Last Active Feb 14 2015 02:22 AM
In Topic: Ford Main Dealer
18 January 2014 - 10:02 PM
No fault codes or anything! Just said they can't find anything wrong and the next step would be to test the injectors.
The car getting progressively worse and had to call the aa out to tow to a garage. They said they think it could be a faulty fuel control valve\solenoid. See wat garage say Monday wish me some luck lol
Sent from my Hudl HT7S3 using Ford OC mobile app
17 January 2014 - 09:10 PM
Coasting and gentle acceleration instrument cluster usually does nothing but sometimes the lights light up like uve turned key to ignition
17 January 2014 - 09:07 AM
2008 but a mk6 1.4 tdci
Egr balnked off and fuel filter changed
17 January 2014 - 07:49 AM
Usually when watm just cruising along the car will cut out for a secound or two then jump back into life like some one turned the key off and on again
16 January 2014 - 08:42 PM
They will defiently be able to make it do it, it happens every time you drive the car but just at random times ive been told it fuel related and if like u say electical tht narrows it down abit. i think its fuel pressure sensor but with out any codes or live data im !Removed! in the wind. You think they will be able to rule out the sensors if its not them?
