djtonymc
Member Since 10 Jan 2014
Offline Last Active Apr 23 2014 10:56 PM
In Topic: Mondeo Cut Out On Idle
16 February 2014 - 12:36 PM
put spair key in and it still the same
11 February 2014 - 03:04 AM
yes i have you checked throttle body it is ok the flap inside are moving freely but ill try spare key as soon as thank let you now
In Topic: Mk3 Mondeo Idle Madness!
10 January 2014 - 11:12 PM
Modeo 1.8 lx petrol
keeps cutting out when turning steering
at first on start up idol goes up and down then it cut out then start up again revs die and give it lots of revs keeps running
put it in garage they put a diagnostics on p1018
replaced map sensor
had a full service
oil change
all filters changed
spark plugs - coil pack - new leads
idle valve
no leaks or splits in any pipes
In Topic: Mondeo Fault Code Help
10 January 2014 - 11:07 PM
Modeo 1.8 lx petrol
replaced map sensor
had a full service
oil change
all filters changed
idol valve
