Member Since 11 Jan 2014
Offline Last Active Jan 18 2014 02:34 PM
Sun Roof Leak
11 January 2014 - 04:05 PM
Hi everybody!
My birds fiesta has started leaking through the plastic trim that goes round the sunroof that covers the upholstery edge. The actual seal looks fine so I am assuming the drainage holes are blocked up which is where I need your help please!
I can't for the life of me work out how to get to the drain holes in the roof. I am assuming they're under the rubber seal but I can't get the seal off to check and worried that the seal is glued in.
Also when I look under the car I can't see where the drainage ends? Would it be in the wheel arch or cil?
To make it easier for me can anybody with experience of this tell me exactly what I need to remove to get to each end of the drainage pipe please? And where they're located... The manual just says the sunroof is a complicated tedious job and should book in with a ford dealer but just for the sake of cleaning the drainage pipe ends I want to avoid having to take it to Ford.
The car is a fiesta 54 reg which I think is a mk5 (possibly 4....)
Many thanks for your help!
