Member Since 14 Jan 2014
Offline Last Active Apr 30 2014 06:43 PM
Fiesta Mk7 Asian/sports Grill
22 April 2014 - 09:28 PM
I can't believe there has been over 400 sold for this price, usually when I've came across them they are usually over £60/£70 at the least. Has anyone actually purchased one? If so how easy is it to fit?
Knocking Noise
15 April 2014 - 04:34 PM
I searched and came across one or two threads regarding this knocking noise on Fiestas but it was from 2012 or beforehand.
Anyhow recently I've noticed this knocking noise from the steering column whilst turning the steering wheel at low speeds and/or standing still. Apparently back in 2010 it was common and there was even a TSB because of it and the conclusion was that there was missing lubricant at the sliding surfaces between the male and female tubes of the lower steering shaft. This may well be the problem I'm having, or it may not be but it seems quite likely that it is.
After I did a bit of research I went to Ford and notified them of the problem and they said they hadn't came across that problem before even after I explained it to them.
Worst of all my Fiesta is only over 1 year old so it's still under warranty but surely it should be covered as it isn't exactly wear and tear?!
Any advice would be appreciated.
Asian Grill / Sports Grill
26 March 2014 - 10:27 PM
Anyone else came across this on Ebay? Only £28, there has to be a catch to it. Surely.
K&m Air Filters
10 February 2014 - 09:06 PM
Does anyone own a K&M Air Filter here? If so, what effect did it have on your car? Whether it's performance, acceleration, noise?
I purchased one and I've noticed a slight difference but despite that the fuel consumption is considerably less than what it was.
