Member Since 20 Mar 2009
Offline Last Active Sep 26 2009 09:53 AM
radio code
06 June 2009 - 03:23 PM
Hi just re connected radio can anyone help me with the code the serial number is M019912. Also since fitting the parrott bluetooth kit the auxillary input inside the glove box has stopped working im hoping it was just a plug comeloose in the back of the set (thats why ive taken it out again) thanks in advance
whirring/humming noise from start up
26 May 2009 - 07:24 PM
hi can anyone help with mondeo 95k 2000 w reg 2.5 v6 ghia x duratech engine. When the car is started up 1st thing on a morning it makes a loud whirringhumming noise which cant be accuratly pin pointed as its quite loud. Apply heavy sometimes light revs and the noise goes. If left to idle before its fully warmed up the noise comes back (if steering is turned or air con switched on ). Thanks for reading my uncles car so would appreciate some advice.
radio code
20 March 2009 - 05:15 PM
can anyone help me out with a radio code for a sony headunit M019912 thanks in advance
mondeo 06 tianium x sony cd unit
20 March 2009 - 01:09 PM
Hi as it says above im fitting a parrot ck3100 to my mondeo titanium x with the sony cd head unit. I have fitted these handfree kits before to other models but before i start stripping the interior has anyone else fitted these before and noticed things i have to look out for, I can only see two issues in doing this 1-can the radio be removed without the special tool and 2-ive got everything in the book other than the radio code so will i need it after unplugging the power (the mini we had before kept its code for about half hour). And if i need the code which is the best way to get it .
thanks in advance everyone
