J03Fiesta
Member Since 16 Jan 2014
Offline Last Active Yesterday, 10:05 PM
In Topic: 2009 Fiesta Titanium 1.4L Alarm Keeps Going Off!!!
08 March 2014 - 10:41 AM
thanks for this, i am infact having the same issue and i suspected it was the boot sensor in mine as i could see the interior light coming on and off at times, do you know if the boot sensor is inside the boot catch, or is it likely to be something seperate.
If your light is coming on too, it'll be your boot.
I stripped all my panels off to see if I could find the sensor and even stripped the locking mechanism itself and couldn't see an obvious sensor, I believe it's somewhere in the locking mechanism, but like I said earlier, moving the bit where it locks onto which is attached to the car up/towards you like 4-5mm fixed the job for me and should do the same for you.
Alternatively you could get a new lock from a ford dealer which costs around the £46 mark, but you'll more than likely still have to move up the bit it locks onto!
Let me know how it goes!
Sent from my Xperia Z1 using Ford OC mobile app
08 March 2014 - 08:39 AM
With my car, it ended up being the boot catch that was faulty and was setting off the sensor, not the bonnet.
I found that loosening the two torque screws on the boot catch and moving that latch/U shaped bit that the boot catches onto when you close it a couple mm up and tightening the screws fixed it as the lock has two stages and because it sunk down, it seemed to have disengaged the lock, alarming it.
20 February 2014 - 11:04 PM
Also, another issue that is pestering me with this car is that my driver seat belt only releases sometimes and when it does release, it like allows me like less than an inch each time, I must yank at it a good 100 times before I can just about plug myself in!
Flipping annoying when I'm in a rush for work or I've got others in the car!
In Topic: Alarm Keeps Going Off In Fiesta 1.4Tdci
17 February 2014 - 09:20 PM
Hey, have you had any luck with finding the problem/resolving it?
I've got a 2009 Fiesta and when ever I've gone back to the car either first thing in morning or after work it comes up on the screen with 'Alarm triggered check vehicle'.
Just WD40'd the bonnet catch as that's apparently a common cause to a faulty alarm to see whether it'll fix it, but it could be an internal sensor!
In Topic: Fiesta Mk7 Display Not Turning Off?
16 January 2014 - 11:00 PM
I've got a 2009 Fiesta Titanium 1.4 with Keyless entry/Start and twice I've had a similar issue where I have turned off the car and stereo, locked the car and then gone back to the car in like the space of an hour or so and it's somehow turned itself on! Any known issues and or resolutions?
Thanks,
Joe
