Member Since 20 Jan 2014
Offline Last Active Jan 23 2014 11:45 PM
In Topic: Ford Focus 1.8 Tdci 59 Plate.
20 January 2014 - 10:02 PM
Thanks. Like i said, i'll let you know how stuff goes and hopefully it might point you in the right direction.
20 January 2014 - 09:29 PM
Ok, I'll get it up on a ramp Wednesday since its going in for a fuel filter change tomorrow.
I'll let you know if the fuel filter was the cause and if i can make sense of what Innotec tells me to do then ill be trying that at some point so i'll let you know and i'll take some photos too.
Thanks for you replys :)
20 January 2014 - 09:18 PM
Yeah thats the light thats on mine too. I just found this on a VW forum. They make it sound so easy
It made more sense to me but i dont know where my "actuator rod" would be? Using innotec says you have to move the actuator rod about to loosen the soot and grim but where would my rod be? and how to **** do i move it? Lol.
20 January 2014 - 08:54 PM
Is the "elm" the yellow light on the right hand top side?
Like i said mine said it was the MAF but i had that changed for a genuine ford part and it didn't solve my problem.
I found a site that says - "you undo the bolts holding the cat converter to the outlet manifold and the holding bolts under the car, drop the converter down a couple of inches. There's a long tube that comes with the kit, you feed that up the manifold into the turbo vanes. Spray the stuff in an hour later spray the second can in and that's it. Worked a treat"
But i don't want to start spraying liquids in my car if i don't 100% fully understand what to do.
Where would this Innotec tube go in the manifold?
Or does the manifold only have 1 opening once i removed the cat?
Do i just trace the exhaust from the back of the car to the engine manifold to make sure it is 100% the cat i remove?
If i put the tube in the manifold can the liquid drain into my engine or how to i stop it leaking into other parts of my engine?
You get a piece of card to stop the liquid spilling out from the turbo but where would this card go?
God it seems so easy when reading lol.
