Monz87
Member Since 27 Jan 2014
Offline Last Active May 01 2014 12:18 PM
How To Turn On Middle Row Fan Blowers
16 April 2014 - 11:21 PM
I've tried all different fan settings and adjusted the fans by the blowers in the middle row, I can't get any heat or cold out of these, the front ones work perfectly but nothing from the middle row, any ideas guys?
How Do I Take This Trim Piece Out?
15 April 2014 - 12:36 PM
The piece under the handbrake lever is scratched so I thought i'd wrap this bit with carbon fibre wrap. So I managed to take it off but can't get the damn thing out because of the handbrake lever, it does't pass through, gets blocked. So I thought i'd try to take off the handle bit of the handbrake lever, can't even take the damn thing off! I can pry off the side facing the centre console of the top cover on the handle but the other side I can't take off. Who knows even after I open the top bit if I can take the whole handle off to pass the trim through. Any ideas guys?
Attached File  ImageUploadedByFord OC1397564446.747291.jpg   123.6KB   56 downloadsAttached File  ImageUploadedByFord OC1397564465.496023.jpg   118.38KB   56 downloadsAttached File  ImageUploadedByFord OC1397564479.363640.jpg   117.69KB   56 downloads
Phone Vent Holder
21 February 2014 - 08:38 PM
I used to have a cheap phone vent holder on my previous Audi, which has a typical standard air vent.
I can't seem to find one for the s-max. I do see on the addison lee galaxy's they have something plugged into the vent, which holds their radio.
Does anyone know of anything? Really looking for something cheap.
Is There A Part For This?
21 February 2014 - 08:20 PM
I recently noticed that my headlight rear bracket has snapped. As a result the whole headlight unit is loose and bounces up and down on the motorway.
It is snapped in the middle as you can see also where it connects to the black cover is is broken.
Can I buy the rear black casing of the headlight? If so, What would it be called?
Or does anyone know how I could fix it, i'm not going to buy a whole new headlight just for that bit.
How To Test Quickclear Front Screen
27 January 2014 - 12:17 PM
Hi guys,
Just recently picked up a 2007 S-Max 2.0 TDCI Titanium Manual.
I'm not too sure how the quick clear screen works, when I press the button, the light on the button comes on and no errors on the convers+ or anything like that.
So how do I actually know if it's working?
There hasn't been any frost since I have bought it, but the other day when it was raining hard and I had the windows closed, the windows got very steamy and with the quick clear turned on only, no blower on, it wasn't really doing anything....
Obviously when I turned the blower on with the 'max' button it cleared everything.
Is that normal? Is the quick clear only for frost on the outside?
