mikeywalker1967
Member Since 30 Jan 2014
Offline Last Active Aug 20 2015 07:06 PM
#360441 Rear Wheel Bearing....
Posted by mikeywalker1967 on 05 May 2014 - 12:22 PM
Can get them out.
Use the old lock nut as you get a new one spray lots of Wd40 on bearing a use a large socket and a big hammer.
To fit new one put it in the freezer for a while and use the old bearing carraige to hammer it in .
Did both rears on my fiesta.
#353008 58 Fiesta 1.4Tdci Engine System Fault Light On Dash Intermittent
Posted by mikeywalker1967 on 12 April 2014 - 11:41 AM
Could be Egr valve sticking.
Mine was going in to limp mode but when you switched off full power restored.
No faults on Dtc.
Replaced valve ,jobs a good un.
#350259 Noise When Turning At Low Speed
Posted by mikeywalker1967 on 03 April 2014 - 09:10 AM
I used to have a vw polo that was doing the same but it was a plate behind the brake disc that used to catch stones and would rub against the disc.
I take it your ford doesn't have a plate behind the disc..
Could be top mount of the shock absorber thats gone dry .
Try squirt some wd up the shocker.
