Halloween Jack
Member Since 28 Mar 2009
Offline Last Active Oct 11 2011 09:52 PM
In Topic: Using Lots Of Oil.
11 October 2011 - 09:22 PM
I assume so as was serviced at Ford main dealer.
5/30 semi synthetic.
11 October 2011 - 08:34 PM
Can't see any oil under the car and like you say it's going somewhere.
Will have to book into garage.
Could be expensive then?
In Topic: Water In Spark Plug Holes
29 November 2010 - 09:41 PM
Just a little note, I had a water leaking from what I thought were the washer jets but turned out to be the plastic T connector that joins the rubber pipes for the jets.
Changed both jets and both plastic connectors to make sure, not very expensive.
Revised washer jets 2.54
Plastic connectors 2.30 & 79p
Both from Ford main dealer.
