Member Since 23 Mar 2014
Offline Last Active Jan 04 2015 09:15 AM
Fiesta Fuse Keeps Blowing
30 December 2014 - 11:12 AM
Hi folks. I seem to have a electrical fault where fuse 22 on my 07 fiesta keeps blowing. This results in me having no front left side light and no rear left tail light. I have changed out the fuse four times now and after a day or two the fuse blows. I have checked the earthing points related to this fuse (e4 and e11) and im getting a good contact.
About a month ago my wifes can was playing up and i used my car a lot to jump start it (her car is now fixed) not sure if this has caused any issues but thought it might be worth mentioning.
Again not sure if this is linked but the motor for adjusting the headlight height inside the front light cluster seems to be operating all on its own as i can hear this when i turn the lights on but without touching the selector (1-4).
Hopefully someone can point me in the right direction on this as its only a matter of time before the police pull me over!!
Many Thanks for the help.
Gear Change Issue
07 October 2014 - 07:36 PM
Hi Folks, just wondering if anyone else has had this issue....
Just recently when driving my 08 fiesta zetec s on a long journey my gear changing become really stiff. Changing gears first thing in the morning is perfect but once everything is warmed up im noticing a big big difference in changing into all the gears?? Its just really stiff to change.
Would be greatful if anyone knows what the issue is and how to fix it.
Many thanks
Number Plate Bulb Issue
24 March 2014 - 09:58 PM
My electrical troubles continue!! I havent had a chance to fix my number plate bulbs yet from a previous post but was driving the car tonight and i now hav no intrument cluster lights on my speedo, rev counter, heater knobs etc?? I know these are all linked by the same fuse but checked this 7.5a fuse and is ok. Any ideas whats going on here?
23 March 2014 - 05:59 PM
Hi folks. Im new to the forum and just wanted to say hi. Im Bryan I drive a fiesta zetec s 2007 from Aberdeen in bonnie Scotland.
Number Plate Bulb Issues (No Power)
23 March 2014 - 05:44 PM
Hi folks. Im new to your forum and require some help. I currently drive a 2007 ford fiesta zetec s.
Ok.....was driving at night the other day when i was flashed over by another car. He told me i had no brake lights except for the strip under the roof spoiler. So i went and got new bulbs which fix this problem. Happy days!
However now both my number plate lights no longer work. I hav been out all day trying to find the reason why, where i have replaced both bulbs, checked the fuse and even replaced some corroded connectors. But still nothing. I then put my multimeter on and there is no power at the bulb connectors i also checked for continunity between both connectors and all good. I did notice when i was replacing the connectors that some of the copper wire strands were blackened (not sure if this tells you anything or not) I have been looking at other threads and cant seem to find a solution and just wondered if anyone has had a similar problem. Any advise would be great as im at a lose.
Thanks Bryan
