Support the club!
starfire
Member Since 01 Apr 2009
Offline Last Active Jun 06 2009 01:05 AM
In Topic: Stiff gears
04 June 2009 - 11:51 PM
it could be that the linkage needs adjusting or it might be your clutch dragging, does your clutch pedal feel ok?
Yes the clutch pedal seems ok,the car has just been into local ford dealers for problem finding but they say theres nothing wrong.As i drove away from there it did it again,as i said before its a brief problems,that seems to be a sticky gear change.there is no gear crunching or problems with other gear selection and if i put the gear stick into neutral then try to select again its ok.
