Speccymike
Member Since 23 Apr 2014
Offline Last Active Aug 27 2014 12:46 PM
In Topic: Whats The Biggest Thing Youve Had In The Back ??
27 April 2014 - 01:09 PM
So it's not huge but the first chance I've had to load it up. Impressed as that box is 4 foot wide.
Sent from my HTC One S using Ford OC mobile app
In Topic: Focus Tdci Juddering/misfiring
25 April 2014 - 08:09 PM
Long shot as I don't know where the egr valve is on your engine.
Years ago when I was having trouble with my td4 freelander (BMW m47 engine) it turned out to be a clogged egr starving the engine of air and causing other issues i.e lumpy engine etc.
As I didn't really know how to sort this at the time I sprayed pure acetone inside the egr every hour or so for a day to melt all the crap out. Worked a treat. Engine ran fine again. Egr valve was removed completely later on.
PS
Any acetone left over will harmlessly burn off through your engine.
Other idea was a faulty injector/s?
Best of luck
Mike
In Topic: Expandable Foam And A Lot Of Tlc =
25 April 2014 - 06:17 PM
That's astounding. Great find.
In Topic: Open Car With Flat Battery
25 April 2014 - 04:14 PM
Glad you've got in. Don't use WD40 as it will attack the plastics ( brother in laws an auto electrician, he knows these things) use spray on white grease, such as easy grease by rapide.
Mike
25 April 2014 - 11:21 AM
Found this
https://uk.answers.y...06151428AAQek7U
Sounds possible, but you may need to be double jointed!
God luck
Mike
