cornishmike
Member Since 26 Apr 2014
Offline Last Active May 20 2014 09:29 PM
In Topic: Rear Pads On 2001 Focus
14 May 2014 - 08:07 PM
thank you admin for your valuable input, and yes good point made regards to spraying wd40, , many thanks
In Topic: Focus Rear Brake Piston Rewind
14 May 2014 - 07:59 PM
Thank you tommy, for your valuable input, I can now go and buy one, many thanks
13 May 2014 - 03:13 PM
I am trying to find out if the rear calipors rewind clock wise or anti clock, as some of the rewind tools say right handed and left handed, so not sure
13 May 2014 - 12:23 PM
i have focus 1.8 2001 hatch with rear pads, and I need to change the pads and I also need to buy the rewind tool, but do they rewind clockwise or anticlock, any help would be greatfull
In Topic: Mk1 focus 1.8 misfire---help!!
26 April 2014 - 11:17 AM
I would agree with what most members are saying, I would say you have water/damp in around the plugs and ht leads, clean everything out and dry, then spray some multi purpose silicone spray on plugs, in around the HT Leads, and then all over leads and coil etc, works a treat and I have not had any problems since, good luck..
you can get a can of multi purpose silicone spray from Maplin at only £6.49. the product code is RE81C
